possible problems related to newspaper
on the centumcellae.it domain we have a site created with wp 5.5.1, we use NEWSPAPER X theme purchased by you and the following plugins, all active and updated to the latest release available.
PLUGINS
AddToAny Share Buttons
AdRotate
Advanced Ads
BestWebSoft’s Like & Share
Category Merge
Custom Sidebars
Disable Gutenberg
Duplica pagina
Embed Plus for YouTube – Gallery, Channel, Playlist, Live Stream
Google XML Sitemaps
Jetpack by WordPress.com
Re-Add Text Justify Button
Really Simple SSL
Responsive Like Box
Restrict Categories
Simple YouTube Responsive
tagDiv Cloud Library
tagDiv Composer
tagDiv Newsletter
tagDiv Social Counter
tagDiv Standard Pack
the_excerpt Reloaded
Widget for Social Page Feeds
Wordfence Security
WP Migrate DB
WP Statistics
WP-Sticky
YouTube Embed WpDevArt
PHP 7.4
Server info
S.O. Linux webxc302s03.ad.aruba.it 3.10.0-862.2.3.el7.x86_64 # 1 SMP Wed May 9 18:05:47 UTC 2018 x86_64
Apache webserver
Php 7.4.8
MySQL 5.5.62-38.14-log
Friday from 12.40 until 13.00 Italian hours and also on Saturday (from 12.00 to 13.00) we encountered problems: the site did not load and gave a blank page (it kept trying to load without ever opening). Then the problem solved itself.
This is not the first time this has happened, but for a few weeks we have updated everything to the latest version.
The shared hosting provider (Aruba) says the problem could also be the theme or plugins (so they say when it occurs they recommend renaming the wp-plugins folder). It seems strange to us …
Could it be from newspapers, as they say, or from plugins attached to newspapers? Or can it depend on other plugins or the server, as we fear, that they manage?
What advice can you give us?
We had thought of making an exact copy of the site (same version of wp, plugins, php, etc.) on another domain (discouraging the indexing of the site) to see if the same problem occurs when the problem occurs on centumcellae.it occurs simultaneously on the copy …
Can this be a useful test?
Another thing we can think of: can it be due to jetpacks?
Thank you
I think that you updated everything but not the theme, you are using Newspaper v 10.3.5 and WP 5.5.1 but only from Newspaper v10.3.6.1 was added the compatibility with WP 5.5 -> https://i.imgur.com/X4AUBUR.png -> https://themeforest.net/item/newspaper/5489609
Please make a full backup to website and database and make the theme update -> https://tagdiv.com/update-newspaper-theme/ and yes, you can make first the update in a staging or sub-domain to see how the update is working.
After you make the theme update and the problem still persists make a test and disable all non theme plugins, clear all cache and try again, is possible to use some untested plugins that can interfere with the them functionality.
Let me know the results!
