Hi guys,
Thanks for the hard work on the theme and support. Is it possible to add a slider to the “big grid blocks” to display/rotate different posts every few seconds?
An example of what I want to do is here, at the top of the page http://harrietsugarcookie dot com
Hello Jessie,
Unfortunately, our theme does not have any such an option that allows you to use Big Grid for sidebar section, but if you want to have a slide in this area, you should use our tag div slide, like this -> https://www.screencast.com/t/9fKzjjoXc
If you are referring to the top slider, our theme has a big grid slide you can set to autoplay using the block settings: https://www.screencast.com/t/gmCOnwjSLV
