Possible to have stock market ticker next to weather on top bar?
I’m curious if there’s a way to put a stock market ticker next to the weather and date on my top bar. Thanks. Could I use the forex ticker option and use a different code? Like this
top bar for ticker
  • This topic was modified 8 years by dvolatility. Reason: added word
It can only be done with custom ode modifications. There is no spot for custom content in the top bar so it can only be created from scratch. Unfortunately custom modifications are not covered by the theme support. You cna fin the top bar files here if you want to alter their code: https://www.screencast.com/t/w4rDi8I6ds
