In the widgets when I apply the block 7 and block 15 (not in others because I have not tried) I apply filter Category: (category). In principle, the post should only appear in that category as with the block 18 or block 9, these if filtered well and show no posts in other categories, but the block 7 and block 15 does not perform well the filter. I tried to put the ID of the category in the field Multiple filter categories: but so does. I take this opportunity to congratulate you on this excellent theme. Thank you for your attention.
Hello solidoes,
I’ve tested on my side and everything works properly. Please try to disable all the active plugins, except Visual Composer, clear all cache and install only the plugins that come bundled with our theme and try it again.
Thank you for the message!
Hi Catalin,
Look at this picture (http://www.periodicoelnazareno.es/wp-content/uploads/2016/01/widget-view.jpg), this is how I configured the widget in the filter field Cartegory: I put Local> Ayuntamiento (Subcategory)
And this is the result: http://www.periodicoelnazareno.es/local/ayuntamiento/
As you can see a category that does not belong to which I have indicated in the filter field (field Cartegory) is displayed.
Please send an email at contact@tagdiv.com and provide wp-admin access so we can take a closer look. Also paste a link to this topic so we can know who you are and what your issue is.
