Post body and sidebar width size
How do I set content body or post body width 800px and sidebar width 336px?
Also, suggest .td-pb-row padding size according to the size mentioned above.
404, Attachment, Category, Homepages, Pages, Sections, Search, Single, and Tag will have the same size mentioned above.
If you will use a cloud/PRO template for the pages mentioned above, then you will be able to set the sizes for content body and sidebar. You just need to edit the templates with TagDiv Composer, click on the element’s columns or row and you will have some settings in the CSS tab, so there you can adjust your width.
Hope that helps you!
