Post body bug (white) and tools missing
this week all my posts’ body appear to be blank, and the toolbar in “new post” page is also missing. I’ve done some research on it and tried pretty much everything I could find: cleaning cache, deactivating plugins, adding “concatenate” line in wp.config, manually updating wordpress, deleting .htacess and so on. Nothing has worked.
I don’t know if it has any connection to it, but the issue seems to have appeared after we changed one of our home blocks to show “random posts” to “latest posts”.
Best regards,
Pedro
Hello revistaopera,
Please ensure that you are using the latest version of the theme (Newspaper 7.4) and only the plugins that come bundled with the theme. If you are using some untested plugins, please try to disable all of them, clear all your caches, purge CDN files if you are using the CDN system and install only the bundled plugins and rule out any conflicts.
Also, if your problem is still there, please try to make a new clean install from scratch and re-install the theme and check the results.
