Post Bug when using IE
There is an issue when creating a new Post with the IE browser. The paragraphs overlap with the Post setting tabs, meaning that you cannot set up ratings as the paragraph options sit over the top. I cannot see all the paragraphs either as if you have a few, there is a conflict between the layers
This problem is only on IE? please try with other browsers too this should solved the problem! the IE do not recognize all the css that is use in WordPress and Newspaper.
Also make sure that you have the last version of theme and WordPress.
