Howdy I bouth newsmag theme month ago and I´d like to say is a wonderful template.
On my home page I would like have a simple post carousel with on top a big header with summary or text
and a big photo then below 4 thumbnails of the old post something like this web page
http://www.revistaenie.clarin.com.
I can’t find any element on visual composer to build something like that or any plug ins, I will appreciate if you can tell me wich plugs or element should I use or find on the web.
Thanks in advance
Best Regards Fabien
There is nos such element in Visual Composer but you can achieve the desired result by combining the existent elements. For example you can use a text block element with a background image like here: http://screencast.com/t/2iWRkOjzzL7O – http://screencast.com/t/cgsc7owFd – http://screencast.com/t/IIIYBxVbZA
This is the example shortcode from Visual Composer: http://pastebin.com/Ahscf3d8 – http://screencast.com/t/FjmsVHsOl
Hope this helps.
thanks a lot for your answer.
I build my site with the newsmag 3 demo just for start point then personalized everything now I see your classic blog demo, and I see on the front page the post with big header and below the photo as start content, and I would like to do the same on my site, could you tell me if there is the same feature on newsman 3 demo?
http://demo.tagdiv.com/newsmag_classic_blog/
thanks in advance
Best regards – Fabien
On indicated demo we use module 15. This module can be used only with loop part so you have to use page-builder+title as a page template: http://screencast.com/t/umQaFZ4kvnv
I hope this helps.
Hello thanks to answer my questions. I try as you indicate me and the module 15 show below the page builder content as the template layout was made. It is possible that this module show up on top? as main post feeder?
The solution you gave me to use a text box with photo made the idea I want with big header and below the photo but must be made manually and we would like a module that feed automatically as regular module or block.
If there isn’t any solutions it is possible to modify the block 13 on visual composer to move the head on top of the photo instead of below?
You can display the content from page-builder after module 15 by editing page-pagebuilder-latest.php file. Basically you have to insert inside do_shortode function the content which you want it be displayed after module 15. Here is an example: http://screencast.com/t/tqHqSS0HEBOa
I hope this helps.
