Post Changing Randomly
With our domain http://cybersecuritynews.com, the post view getting changed randomly for some posts from the default view. Again we login with the admin portal it gets corrected automatically.
Default view: https://ibb.co/6N1btsQ
Changed view: https://ibb.co/wMNhSvG
Kindly check and suggest a fix.
Regards,
CSN
Hello !
Make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
