Post Comments issue
Hi all,
i’ve been having this problem with the comment:
– at the post creation for some reason the posts didnt automatically have the comments enabled.
– I then enabled them manually and this started appearing : http://screencast.com/t/GW2ssCZewI
– I should add that right now the disqus comments plugin is also active on the website, but it was visible only very briefly. Now it doesnt seem to be able to assert itself over the regular comment box.
The final resul i wanna reach is to have disqus active and no “NO COMMENTS” tag over the comments section.
Thank you
Alessandro
P.S. if you wish to take a look at the website. its http://www.dronesjuice.com
Hello Alessandro,
You can remove the comment titles by using custom CSS:
.td-comments-title-wrap{
display:none
As for disqus, please unchecke this setting from the dashboard: http://screencast.com/t/dWRjZ9sEK8l
You can also follow this topic to get a few tips for disqus settings: https://forum.tagdiv.com/topic/disqus-comments-not-showing/
Let me know how it goes!
