post default template lost and not displaying posts as required
In the last hour, my Newspaper Theme Post Template appears not to be displaying correctly. Both WordPress v6.0.2 and Theme v11.5.1 are up-to-date. I was just updating a post and have not made any changes to template files for this to occur. I use the Newspaper themes site-wide default post template.
I am not a web developer, so any help would be appreciated.
I also have this problem, started today also
Further to my initial comments above…
Upon further investigation, my customised pages are affected too. For example, the site’s header/footer no longer displays, background is affected, just to name a few.
hopefully this can be fixed asap!
Have you tried to see that this issue is not caused by a plugin conflict?
Usually, this issue is caused by a plugin conflict, please do a test using the theme plugins, clear all cache, and see if the problem persists.
I have the same recommendation, because if it worked before, then it means that either you added a new plugin or a plugin updated itself and it interferes with the theme.
I’m not updating anything and my site got the same situation as the thread starter. Please fix it ASAP and please not asking us to clear cache, this is tagDiv bug
This issue seems to be resolved for me. I deactivated/reactivated a Cookies Plug-in I recently newly installed 3 days ago. The template conflict I was experiencing seems to be back to normal. If this continues to reoccur, I will remove the cookies plugin permanently.
Many thanks!
i also have this problem
Hello @Yoshiyu and @sociallyacceptable,
As you can see in these topics,
-> https://forum.tagdiv.com/topic/template-post-display-error/#post-453190
-> https://forum.tagdiv.com/topic/theme-is-broken-on-articlesheme-broke-on-articles/
a plugin caused the problem; maybe there is a setting that causes this problem, considering that it was working before, so please check it yourself.
@rronan, I’m glad the problem is resolved.
Im experiencing the same problem. tdb_template_5792 template is set as default single post template, but not by me. Cant change this settings.
The problem was fixed after I upgraded WordPress to the latest version.
I’m glad that your issue has been solved.
Have a wonderful day!
