Post feature image display problems
I am having some problems with feature images on my site at the minute. They are only appearing in one or two places that should be and i don’t understand why…
So i can see the feature images on the post themselves, and in the backend of the page editor when you select the image.
But i can not see the feature images in the media selector panel (it shows just a file icon with the name of the file), and on any of the pages on the website itself it just shows a blank space where the image should appear.
This is also affecting all images i upload to the site now but not ones that i have uploaded prior to this. Would be able to help me this is quite frustrating.
thanks,
coner
Bump, any help on this would be greatly appreciated, really can’t figure it out.
Thanks,
Coner
Hello Coner,
“Bump” on our forums has the opposite effect you only delay your answer.
This could be a plugin conflict so please disable all plugins except visual composer, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
