Post filter Sort Option required
hi i have tabs in alphabetic order you can see in this pic https://www.screencast.com/t/sMevlFAx
i want to sort the post mean if i click on “A” tab the block show the posts only start with title “A” but block sort have only this option A to Z mean block will show all post if post title starts with “B” i want to show only posts which with Starts with “A” character , im using block 15
Sorry but our theme does not have such a sorting option available as you require. There is an alphabetical sort order available but you cannot select just the letter you want from the alphabet to show. It will show all posts in alphabetical order. You cannot select just posts that start with a certain letter. Sorry.
now add this option in feature update??
It will be considered for implementation only if the request becomes more popular. There are many other suggestions and recommendations that might have higher priority.
