Post font not same as setting after update v9.7.4
I just updated my blog to 9.7.4 and got two problem. my blog link is https://irfan.id.
1. Post font don’t follow as font setting. Please look at this pic https://prnt.sc/ohk7wr, post content font should be Sans Light, but it’s not (blue box). Meanwhile, font for the list followed as setting Sans Light (green box). Post content and Lists font should be the same.
2. I tried to change mobile theme font. But it doesn’t change the font, only font size changed.
Thanks,
Irfan
Please make sure that you do not have a plugin conflict with untested plugins, please deactivate all non theme, also if you are using child theme, clear all cache and try again.
Also make sure that you clear all cache after you make some changes.
If there is still a problem, please provide some more details and a link where I can check this problem of fonts.
Also the mobile fonts is applying only on some elements from the mobile section, please provide some more details about the settings you’ve made and the problem that you are facing.
