post format video Problem
I have migrated to latest version of newspaper theme, i see video posted previously are not showing up
http://www.tollywoodfans.in/24779/jyothi-lakshmi-trailer/
is there any way we can have a specific post style for each post format or
specific post style based on the category
Not sure what the issue is as I cannot access your site – http://screencast.com/t/MAnrOK5is Did you used your videos as featured?
You can check this also without any plugins active except of Visual Composer, clear cache and purge your files if you use CDN.
Hi Alin,
This used a video as featured which is done during the V4 version and Now its show nothing …
-TollywoodFans
I have checked your articles and you use post style 5 that’s why your featured video is not displayed on your post page – http://screencast.com/t/JLXBZ8BN so please change the the style and see if it works.
This videos are posted during the previous version of newspaper theme …. how can we change the post style for all the posts
Check if they are set individually or they take the global settings from Theme Panel – http://screencast.com/t/rKAa56MKz
I’ve also checked the old template(v.4) and on style 5 the video or featured image shouldn’t show up. – http://screencast.com/t/bfwFris8IY – http://screencast.com/t/kZ964nKlH
Maybe you had some modifications on the old template, if you have a backup of your old theme check if the template was modified.
i dont remember exactly which template i used in my old template, is there any solution that i can modify in the current template “post-style” for post-format “video”
The issue is not with the post format, eve if you change it to video format(or standard) it will not resolve your issue because you use post style 5 that it will not show feature video/image – it was designed like that. This template was the same also in version 4 of the theme, so I’m not sure what custom modifications did you have in previous version.
A solution is to copy featured image code also in this post template – http://screencast.com/t/TUDHnOoo – http://screencast.com/t/xet4KkaGtj8
