Post From Same Category Look the Same
Is there a way to make all post from the same category to look the same? so it can look like same section?
Thanks in advanced
Hello masc,
Unfortunately, our theme does not have such an option for your request but you should take a look over this topic here -> https://forum.tagdiv.com/topic/different-post-template-for-one-category/ and try to implement yourself this workaround in this case.
Please notice that is not a simple task and if you are not aware of the steps in this regard and if you want to display more levels in our theme without success, please consider hiring a freelancer/developer to help you because we cannot provide customization services at the moment, sorry!
Hope this helps!
Ok, it works!, and how do we configure a especial sidebar for this workaround?
so, we can have special posts for this category and different widgets.
Hello masc,
Unfortunately, for accomplishing this request are required more additional customizations through the code and at the moment, we cannot provide customization services, sorry! If you want to display more levels and features in our theme and you are not aware of the steps in this regard, please consider hiring a freelancer/developer to help you!
