The response I got from WPBakery –
The issue is most likely because there is an inbuilt version of visual composer (or the related code) present in your theme which is overriding the standalone plugin version and hence causing the issue. You will have to get rid of it. I would advise you to do so with the help of theme author, otherwise you might loose the extra elements added by him. Once this is done, you can install the standalone plugin and it will work fine. Kindly check.
Thank you,
UPDATE: I have tested your theme with a CLEAN install of WordPress only with visual composer. The POST GRID does not work as it should be so the problem is from your theme – please don’t give me the usual crap or tell me otherwise the problem is from the theme.
Hey, look at the info top right of this page: hours of support ? Closed weekends. It’s now Sat/Sun. They will be back on Monday.
Support Hours (GMT+2)
Monday - Friday:
8:00 AM - 17:00 PM
You can’t easily use the standalone version of Visual Composer with this theme, since it includes its own bundled version with custom code. The theme only “out of the box” supports the bundled version. You’re somewhat on your own if you want to use the commercial version of the plugin.
Without a link to *an example page* where you have the problem, it’s unlikely you’d get any help. You can also email tagdiv support directly with your example page if the site is not yet public.
So some of the shit and crap is waiting on you to address. You would need to modify the theme to remove its built in code for Visual Composer.
For the theme to work as provided, you need to REMOVE the commercial version of Visual Composer, and follow the installation directions and install the version INCLUDED WITH THE THEME. That is what it’s for. You can’t have both.
Hopefully that crappy answer will help with your shit?
simchris.
You keep saying you have no problems on your websites etc. How did you get yours to work? The post grid is only supported with the newest Visual Composer which is not provided by the Theme at the moment because they have not updated it yet.
As I told you I don’t know what you think of me but I tried the theme on a clean WordPress INSTALL with the plugin Visual Composer and still doesn’t work. I did that to see where the problem is – it looks like the problem is from the theme.
Sorry. I am using the Newsmag theme which has this option. The Newspaper theme does not yet have it, but is supposed to get new version once the memory hog issue is sorted which is causing sites to die with latest version of VC.
I am using Newspaper theme on couple of other things, but using the built in post grids including with the theme. 🙂
simchris.
Thanks Chris!
@kovachx
Sorry for the delay, we don’t work on weekends!
We will add the updated and tested version of the VC plugin in the next theme update. I suggest you use the VC plugin provided with the theme files as updating it could cause issues like in your case.
Unfortunately we do have some issues with some of VC elements on which we are currently working and plan to fix within version five of the theme.
I’ve also checked your site and noticed that you’ve set up the rev slider plugin for this which seems to work fine.
We are sorry for the inconvenience caused!
