Hi there,
We’ve set the accent colour to be red and most elements are working fine. But whenever we try to link post subheadings (we mostly use h4), the headings turn back to black whilst the unlinked ones are red.
We’re currently running on Newspaper 8.
For your reference: https://hongkongliving.com/best-kindergartens-hong-kong/
The post content elements can be colored as you wish, when creating/editing the post
– https://www.screencast.com/t/uXXqaOEFF
Or all at once with the option in the theme panel for headings color
– https://www.screencast.com/t/9xkyanI4QZ
The color you set there would apply to all the headings in the post content, regardless of linked or not. I have tried setting a color for the headings, and it is applied in both cases, link or no link.
Hi Simion,
Thanks for getting back to me.
We’ve set the headings colour as the same shade of red as well but the headings still turn back to black after we’ve linked them. Do you know of another way how this might have occurred?
Thank you so much!
That could happen because of the theme accent color, this will override the setting I mentioned and color the link with the accent color. So as soon as you create a link from the heading the color will be the accent color for it. I could give you a code for this specifically for the heading links, like this
.td-post-content h4 a {
color: yellow;
You can multiply it for the other headings if needed
– https://www.screencast.com/t/gTWohZap
Or you could chnage the theme accent color as I see you have done already.
Hi Simion,
It works perfectly. Thank you very much for your help!
