Post ID Filter Not Removing Posts
When using the post ID filter in TD Composer to remove posts, it works while in TD composer: http://www.screencast.com/t/cWObbw3T
But still shows the posts when viewing the website: http://www.screencast.com/t/ZneucQOYpnMm
I’m trying to remove individual posts with the filter by entering them with the minus symbol in front of the post ID.
If this is not the correct way to do it could be please tell me how?
Hello lukehodge,
I have tested this feature on my end and it seems to work as expected, without any problem. Do you have cleared all the caches from your website? Try to do this and check the results.
Hi Catalin
Yes I’ve tried deleting the cache in WP super cache and tested it on multiple devices.
The posts I’ve listed in the filter to be excluded from the block still appear on the page.
Is that how it’s supposed to be done?
Hello lukehodge,
If you are using some untested plugins you should remove all of these, clear all the caches and check again the results. If the problem is still there, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can take a closer look at it. Provide there the link to this topic so we can quickly identify you.
Thanks, the new update to the theme fixed the issue
