Post Layout Issue (Sidebar Not Displaying Properly)
Hey,
I just published this post: http://fightpassport.com/mma-workouts-and-nutrition/supplements-for-muay-thai-bjj-mma/
The problem I’m having though is that the sidebar is appearing in the footer, and on page 6, the text actually appears in the sidebar: http://fightpassport.com/mma-workouts-and-nutrition/supplements-for-muay-thai-bjj-mma/6/
The settings for the post are to have the regular default sidebar, which is the sidebar on the right hand side.
Any idea what might be happening here?
This issue usually appears when the theme css gets rewritten. This can happen due to an incompatible plugin or due to custom modification, but as i see full width elements on your website I think it’s safe to assume it’s the custom modifications you made to the theme. Please remove your modifications and test if the sidebar displays the same without mods.
Hey Bogdan,
I don’t recall making any custom modifications to this theme.
The bottom side of this post: http://fightpassport.com/mma-workouts-and-nutrition/supplements-for-muay-thai-bjj-mma/6/ appears to be in full width and this is a big request we always get by our users and everyone wants to have it like so. That is why i assumed you modified the theme to have it like this. If you have not modified anything that means that it could be a plugin compatibility issue.
Please disable all your plugins except visual composer, clear your cache and purge cdn files. Then check the error again.
Let us know if the problem is still there.
