After update, my layouts for posts are not the width I set them too. I need to fix this asap as we launch our new issue in two days.
Hello Liz Painter,
I suggest you make a new clean install to another subdomain for testing via FTP way, remove all of the untested plugins if you are using something like this, clear all the caches and check the results. Also, you can provide your website URL for further investigations.
It works in every way except desktop view.
Hello Liz Painter,
I have inspected your console and I saw that you are some errors through it -> https://www.screencast.com/t/USpe4cruZfZ and also, I saw that you are using some untested plugins which can cause this -> https://www.screencast.com/t/cfQl3vslz Please try to disable all of this, clear all the caches, purge CDN files and check the results.
I didn’t have an issue until I updated to the latest Newspaper. I have to have these plugins as well.
It’s a little over my head but how on WordPress do I fix those errors and purge CDN files. Will that affect anything?
Hello Liz Painter,
For the beginning, you should remove all of your untested plugins, leave just to active only the required plugins which come bundled with the theme core files and check the results. Regarding on CDN, you can read here -> https://wpexplorer-themes.com/total/docs/clear-site-cache/ about this case.
