Hello! When I add my google Ad Code to the Post Loop Module it will not save it. If I click off the module and come back to it, it’s blank. Does the Post Loop Module only support an Image Ad?
Here is the place I am putting the code. View Image
I just noticed that if I copy and paste into these fields and into other areas like button URLS it’s not saving it until I add an extra command such as hitting the “enter” button then removing the extra space. Could be a server issue if not you’re not able to replicate issue.
Hi TWDesigns, there should be no problem to set any kind of code in ads section, but most probably it is a copy/past problem. What I suggest is to copy the code in a editor, save it there and then copy the code from editor in the theme ads filed. Also, the method you mentioned should be working (testing something or letting some empty space).
I also notice our developers to check this situation, maybe it is something related to focus or save the pasted information in the ads filed.
