Hello
We are pulling certain featured or selected post in each post loop but we cannot select category in post loop 2 element.
check attached screenshot for better understanding. Please let us know how to load any post of these categories in this element.
You can’t filter the block Posts Loop, you can only sort it => https://www.screencast.com/t/geckLSYd5sa, so if you have set the Posts Loop on the homepage, then will display all posts of all categories, if you have set the Posts Loop set on the category template, then will display the posts only from that category.
You can apply the filter only on the Flex Block and Big Grid Flex -> https://imgur.com/Nnt3zGX
how you guys ignore this simple feature to load post with category in loop.
is there any way if i can create similar widget on homepage with each filter’s box ?
You can use the flex block 1 and apply different filter on each block. Check this guide:
https://forum.tagdiv.com/flex-block-settings-guide/
