Hi.
In the categories template, I have the post imported the Medicine Pro template.
It has a post loop on top and a post loop at the bottom of the page.
I have set for the second post loop to have an offset of 2 and 9 posts limit with pagination.
What I get in the front end is the posts on the second one are the same as the posts on the first loop (offset not working), and I can only see 3 posts and have to press to load more (post limit not working). This is for any category.
https://1.boxnews.gr/category/lifestyle/
I used a ready template for the categories.
The ready template has 2 post loops on the same page.
I did not change anything.
Do you mean that the templates are wrongly created?
Hi efstratios,
I just check the cloud template for Category Template – Medicine PRO and this has only one post loop -> https://i.imgur.com/lQX8iCW.png and more flex blocks maybe you have set in footer or somewhere the second post loop or something.
