I cannot see what the difference is between the post loops and flex blocks.
Fx I load a post loop from the template library, what do I miss or get?
Thanks in advance.
The Flex Block settings are divided into 5 tabs: General, Filter, Layout, Style, and CSS. However, don’t confuse the Flex Blocks with the Flex Big Grids as they have a different layout.
The Posts Loops settings are divided into 4 tabs: General, Layout, Style, and CSS. The Posts loop is a special block and doesn’t have filtering options.
Also, one of the options for pagination of the Posts Loop has the option for normal numbered and the flex blocks do not have this option.
The Posts Loop is automatically filtering the posts depending on the cloud template you set (for example on the category page there will be posted posts from that category).
