Post meta td_post_theme_settings “subtitle”
I would like to get the value of td_subtitle from the meta_key : a:1:{s:11:”td_subtitle”;s:15:”Bordj Ménaïel”;}
or like this : a:2:{s:19:”td_sidebar_position”;s:13:”sidebar_right”;s:11:”td_subtitle”;s:31:”Ça a marché à Béjaïa aussi”;}
Thanks in advance
Depending on what you want to do and where you want to set this value, using a single post template, you can use the subtitle element to display it in any place you want to have it on a single post template.
If you want to create a custom template in a child theme you can use the php code: https://pastebin.com/DPW5s2nX
