Post | Mobile | Side to side inside content
Would like to know if there is a possibility to have images inside blog posts to show on mobile from side to side.
Currently: https://prnt.sc/oir78t
What I would like to achieve: https://prnt.sc/oir7iv (this is the header image)
Any questions, please let me know.
Regards,
Z
  • This topic was modified 7 years by webforu.
All the post content is inside a general container, this container will set a padding for it, like this – https://www.screencast.com/t/k961Db0A
Removing that padding would make the images be edge to edge, but so will the the rest of the content, which won’t look nice. Some CSS could be used, like removing the whole padding, then applying it for everything but the images.
But this means that all the elements used inside the post content have to be taken into account (paragraphs, lists, maybe divs, all the headings etc). I could create a code for it if you should consider this. let me know.
