Post not showing when using Category filter set in Block Filter
Site url: https://aodww2.com
We’re using Block 17 bit it happens with others we’ve tried. Using a Category filter that relates to Post Category. Shows in TD Composer, but will only show 2 and then shows empty when 3rd is added to row. This feature was working but has stopped working.
  • This topic was modified 5 years by reded.
If you use a filter category like: Single – More from author, Single – Related by category, Single – Related from tags, please make sure you place that block in a post template to have effect.
If this is not what you mean, then please provide more information about your issue.
Here is a short video showing the problem and our code:aodww2.com Category Post problem
  • This reply was modified 5 years by reded.
Let the offset field empty with no space, no value and see the results: https://www.screencast.com/t/A4fx6DF2
If the problem is still there, then please send an email at contact@tagdiv.com and provide wp-admin, so we can investigate this issue. Also paste a link to this topic so we can easily identify you.
