Post not shown on mobile devices
Yesterday I wrote an new post. But it is not shown in mobile.
http://makanangin.de/ayurveda-in-indien/
What the problem?
What can I do.
I can give you the admin:
Please give me a help.
Best regards.
Regine Richter
  • This topic was modified 8 years by Simion C..
If you are not using the mobile theme, the same content you have on desktop will be shown on mobile as well.
Depending on your filtering and sorting the new posts once published will be shown in block/grids etc in pages. The actual post and post content will be shown in both desktop and mobile theme.
The post page you have provided seems to be broken. The mobile theme is displaying on desktop when it should not. That is in most cases caused by caching plugins. We recommend the WP Super cache, this will work with the mobile theme properly.
So please try to deactivate the cache plugin you are using and clear the cache, Check if this solves the problem.
I will remove the login details you provided, note that this is a public topic. Everyone can see them. If we should require them at some point we will ask that you provide them by email.
Hi again,
that was not really the problem. I think there is a problem with the plugins from the theme. I deactivate all – now it works.
Best regards.
Sorry if I misunderstood. Please try and provide all the details about the issue so we can investigate.
You published a post and then you did not see it on mobile. Are you using the mobile theme? if not are the grids/blocks set to display latest posts? Is that post a custom post type (mobile theme does not display custom post types)?
Let us know.
