Post Picture Attribution Section
I’m writing to find out if this theme supports post picture credit/attribution.
In other words, say I write an article and I use a picture from Wikipedia or Getty Images, where I have to give credit to the picture source, usually in small text under the picture to the left or right of it. Does this them support that feature?
Here is an example: https://www.screencast.com/t/znXFXTz7D
If the theme doesn’t support this feature, can you recommend a good plugin for that feature?
You could display a caption below the image – http://prntscr.com/kfp122
There you can write the source of the image for example. Each image can have a caption so this could be a solution.
Simion,
Thanks for the reply.
Your suggestion is spot on for pictures inside of a post.
I should have been a little more specific, I’m looking for a solution for credit/attribution for Featured Images that get displayed in posts at the top of the post (the main image/video), not images embedded in a post among text.
Does that make sense?
Some post templates display the caption if the featured image has one. But for a featured video a caption cannot be set.
There is also a post subtitle field, which will appear in the post page
– https://www.screencast.com/t/2XK5ml8O
– https://www.screencast.com/t/5xoMBUZZMa7y
Other than that there would be no option I can think of.
Simion,
Thank you for the response.
What you are suggesting is practical, however its not a fit for our application.
We need to be able to provide credit to the featured image to show where the image was sourced from. The credit is usually in small lettered displayed to the left, centered or right of the featured image but only visible on a post.
Here is the perfect example: https://www.screencast.com/t/Khg2ulfB9fI0
Thats small text can only been seen when someone reads the article, its not displayed if the article if featured on the home page or anywhere else on a website.
In the US, for legal reasons, one has to cite the picture/video to give credit to the originator.
I’m guessing what I’m asking for is not a native function to the theme, but would you happen to know of any plugins that provide that credit/attribution filed to be included with the featured image, but only displayed on the post?
Also, I see that you are using screencast.com, hope you like it 🙂
That seems right, maybe with a plugin that is possible. A plugin that can add extra fields to images and videos or a cite plugin would be a solution. You could make some tests with such plugins, I did not try any unfortunately.
Currently the theme does not have a dedicated field for this, but I can add it on our request list. It would be a nice thing to have by default in my opinion, so it will be considered.
I don’t think there were any mentions of this previously, probably there are working plugins that are used where needed.
Thank
Simion,
I checked out some plug-ins and they all seem to be outdated, in other words they haven’t had updates in a long time. If I install, they may compromise the security of the site, unless you think it wont cause any issues.
But, yes, I agree with you that having that option available and native to the theme would be great and would make the theme more competitive for news like sites that need to cite picture sources or provide picture attribution in the USA.
Looking forward to that update.
Thanks for your help!
Want to add my request for this feature. A separate field, that could be formatted differently via CSS, would be idea. I’m using the Caption field, which is okay, but it leads to some weird issues, especially in galleries.
Simion,
I saw that lakersnation.com, a big blog here in Los Angeles, and they use the Newspaper theme Version: 2.3.4 (rara) and I see that in their posts, they have a featured image credit/attribution section:
See example here: https://www.screencast.com/t/ORNNfVuugN
Article: https://www.lakersnation.com/lakers-news-enes-kanter-details-big-problem-with-lebron-james/2018/08/27/
Code snippet: data-caption=”Brad Penner-USA TODAY Sports”
Is that a plugin or do you think its custom code?
Hello rocketman,
Here is talking about an image caption which can be added from the editor, when you load an image. -> https://www.screencast.com/t/ThFYU1mwH If is not what you mean, provide more details so I will be able to provide a more accurate response.
Catalin,
That is exactly what I was looking for. Thank you!
Have a good one!
Yes, I know how to add a caption, and for now, that is what I do.
BUT, there are two problems:
– On a regular image, there is not a way to customize the attribution differently from the caption (as far as I know). The caption is already italic, which would be the normal attribution treatment.
– And, on the tagdiv gallery, there is no way to separate the caption from the attribution either. On the gallery, especially, it would be very nice to have the caption larger, and the attribution separate and smaller. As it is, I have to put the attribution inside the caption, which really looks ugly.
So, I’m back to asking for a separate field that could be used in both regular image inserts AND in the gallery. Thanks!
@BruceInLouisville
Thank you for explaining your challenge it in detail. Yes, I understand where you are coming from now. And yes, your recommendation makes sense; I’m with it as well.
Here are my thoughts…Perhaps the italics can be removed from the current caption field while making the font color black. The credit/attribution can be a font smaller, italicized and gray color and assign right indent so caption inherits the left indent.
That way there will be separation in the text and readers will easily identify the distinction between the caption and the credit/attribution.
