Post preview function does not render correctly in 10.2
The 10.2 update screws up the Post Preview function on our site – in Preview mode the content renders as a narrow central strip, with all text to the right missing. An error message appears at the end of the post (see below). It is impossible to test the post appearance this way. Fortunately the posts render correctly when published, but having to publish before you see the appearance is a bad solution. Can you look at this and fix please? BTW, the 10.1 update did not show this problem.
ERROR MESSAGE
Fatal error: Uncaught Error: Call to a member function format() on boolean in /home/ethical1/public_html/wp-content/plugins/td-composer/legacy/common/wp_booster/td_module_single_base.php:672 Stack trace: #0 /home/ethical1/public_html/wp-content/plugins/td-standard-pack/Newspaper/parts/single/loop-single-8.php(33): td_module_single_base->get_item_scope_meta() #1 /home/ethical1/public_html/wp-content/plugins/td-standard-pack/Newspaper/parts/single/single_template_8.php(53): require_once(‘/home/ethical1/…’) #2 /home/ethical1/public_html/wp-includes/template-loader.php(98): include(‘/home/ethical1/…’) #3 /home/ethical1/public_html/wp-blog-header.php(19): require_once(‘/home/ethical1/…’) #4 /home/ethical1/public_html/index.php(17): require(‘/home/ethical1/…’) #5 {main} thrown in /home/ethical1/public_html/wp-content/plugins/td-composer/legacy/common/wp_booster/td_module_single_base.php on line 672
There has been a critical error on your website.
Hello !
Unfortunately at the moment this is a bug which will be fixed in the future update. As a quick fix you can enable this option and it should work: https://www.screencast.com/t/0vuuaaDwyh
We are sorry for the inconvenience !
