Post Review Stars Rating: Make it 10/10, Stars Not Showing in Big Grid smaller
Hello TagDiv team and members,
I discovered that the Stars rating do not show on the smaller tiles of the Big Grid. So is there a way or a tweak I could do for it to show?
Also I want to max out the stars from 5/5 (0.5 increment in final scoring) to 10/10 (1 point increment in final score), if this would be possible and easy then I would probably go for it but if now, then I will likely go for the percentage.
http://1drv.ms/1HWRatL
Looking forward for your help guys.
To add the rewiew stars in all thumbs from big grid insert this line of code:
<?php echo $this->get_date();?>
here: http://screencast.com/t/yyKouvEk Here is the result: http://screencast.com/t/Ir0MO4sqRRv
The review was designed to work with 5 stars and it’s not an easy task to change it. The code for review it located here: http://screencast.com/t/9n1wQ6D1Uvkf and also for backend here: http://screencast.com/t/ohdVNxfDITM feel free to change it if you want as we can not offer custom work at this time, sorry.
  • This reply was modified 11 years by Andrei L..
Thank you so much for replying Andrei. I really appreciate the effort. 🙂
I was partially right that the 5stars to 10 stars is on difficulty level. But I will take a look at it in the future.
