Post Setting and Feature Video is note showing
Dear Admin
Kindly note that the Post Setting and Feature Video is note showing when we open new post
Any clarifications ???
That is unusual, those fields should be available for default posts (not for custom post types). Please check in the screen options if the post settings and featured video fields are enabled in the screen options
– https://www.screencast.com/t/CDb3UHDJA9
If there is still a problem, try to deactivate all plugins except theme plugins. Check if this has any effect.
Thanks your help the plugin that marked the error is
https://givewp.com/
I have the same issue, also caused by Give!
Thank you for helping me to find that out.
