Post Settings are not visible for my authors
Post Settings are not visible for my authors, and also my menu template disappeared.
What might be the issue?
My authors are not able to see post settings, I’am able to see from ADMIN on my side.
One more questions, my Header menu template dissapparead and I want to replicate the old menu, how to make what I marked with RED with BLACK, I want it to be black – https://www.dropbox.com/scl/fi/42e9qjzh3px3jh5ukyamq/Screenshot-2026-05-26-at-00.21.11.png?rlkey=3kz1veismh8ynflppo5g8tztg&st=u4v5ejdi&dl=0
Best,
Klaus
As far as I know there’s no issue with the post settings currently. I checked as an author, in the block editor the post settings are there at the bottom -> https://prnt.sc/no-yHvBANdHI They just need to be opened and it’s all there -> https://prnt.sc/XFSq26yfORLf Same with the classic editor -> https://prnt.sc/tInILVzc8Ud2
If the settings are truly missing on your website, maybe it’s some kind of plugin conflict. That’s the first thing to check.
If you used a cloud header template before, it couldn’t have just disappeared. From what I see using the wayback machine, you used to use a standard header template, template 5 -> https://prnt.sc/VkP4uig1R0m_ That kind of template requires this plugin -> https://prnt.sc/rQ-ehi9kAEad then you can use it again. If that standard pack plugin is not active, then yes, some settings from the theme panel won’t be available.
Or would you like to switch to using a cloud header template? I’ll help set it up if you want.
Multumesc mult, am fixat totul.
