Post Settings Issues
Hi. I have no idea what happened, but now when I click on “General”, “Smart List”, “Reviews”, or if I try to choose A Post Template at Post Settings section it does nothing, just jumps the view to the top of the screen.
Does anyone else has this issue since couple days ago?
WOW. Same thing with Theme Panel. NOTHING works, anywhere I press, it just jumps to the top. Only thing that opens any settings is IMPORT/EXPORT. Thats it.
What is going on??
After deactivating all plugins and activating one by one found that the problem is caused by WP Statistics Plugin.
I had the same problem, thanks for solution.
