Hi!
After updating to 7.3 version i´ve detected a problem, that when someone without administrator role is writing an article, they don’t see “Post settings” block in the editor to set ‘subtitles’, ‘ratings’….
How could i fix it?
Thank you
Hello romerito13,
Please ensure that you have checked it the post Settings option to be activated from the editor, like this -> http://screencast.com/t/GkYnmpbjAnMm
If is not what you mean, provide more details.
No, it doesn´t appear this option, as you can see:
http://i68.tinypic.com/2mepa9h.jpg
It was after update theme to last version
If the post settings do not appear on your site, please disable all plugins except visual composer, clear cache and reset cdn files if you use it. If you still have trouble with this please contact us via email at contact@tagdiv.com and provide a link to your site and admin information so we can login and investigate.
Thank you1
