Post Settings Reviews Custom?
Is there a field or somewhere I can edit the colour for the Product Review Stars? At the moment they are black and don’t look very friendly. I would like to change them to red.
Vince
If you are referring to the stars on the homepage (on blocks) you need to use this css top change the color:
.entry-review-stars{
color:red!important;
If you want to change the color for the ones on the post itself, you need to use this code:
.td-review-final-star{
I hope this helps.
Thank you for your timely response.
That worked quite well, I made the alteration to the red with #942626 and looks much better.
The review stars that did not change are the stars for each individual star percentage setting. Can you please advise?
Vince
It would help if you provide a link to your site so I can inspect the stars and provide the proper code.
It’s on a test site. How do I provide the details privately?
This is for the stars on desktop and mobile version using the Newspaper theme (news/magazine).
Vince
HI
Replace the previews code whit this one: http://screencast.com/t/qOmT4IJf0R
.td-review-stars, .td-review-final-star{
If it still does not work you can address us via email at contact@tagdiv.com with a link to this conversation and also give us wp-admin so we can have a closer look.
The preview stars are working, however, not on mobile. I have sent an email to you with logins.
Thanks for your help
Vince
Replied via email!
