Hi Guys.. Like the post settings templates.. I am trying to use style 3 (big photo on top) and I can’t figure out how to get an image in there. I have a featured image set for the post.. I tried adding the url into the source url in the post settings area.. but no image shows up.. just the title of the post and a grey/black gradient background.. (Which i assume is the default)
Can you point me in the right direction to add the image.. THANKS.. I know it is probably easy just haven’t found it yet.. heheh
William
great theme btw.. I know you guys are working through bugs.. but it is pretty amazing.. I haven’t even tried to rank things and my posts are being indexed pretty high.
Please make sure you have the post set like this: http://screencast.com/t/FsvGCEVFHxbu
Should have a result like this: http://screencast.com/t/SpVQYrwcZ
Send me a link to a post that has this problem so i can check or include this topic link or specify this in the e-mail regarding the mobile slider issue if you can’t manage to get this done.
Works fine for me – http://www.droidgobl.in/2014/08/09/review-nuggets-icon-pack-by-mindplay-media/
If you’re using Cloudfare, make sure to disable Rocket loader and JS minify.
