Here the link http://peekworthy.com/17-of-the-hottest-pictures-of-katy-perry-you-will-ever-see/.
Please check Post slider with next and previous button is not working yet. when i have click the next and previous button slider is not working.i have checked theme setting.but it is not working.I have configure slider according to theme documentation. but still it’s not working.can you find why this slider is not working.
Unfortunately I;m unable to see the “post slider” as you changed the smartlist type and it does not slide now.
In any case, this issue is generally created by plugin conflicts: (browser console errors: http://screencast.com/t/nnR3XDUV) Multiple things break when plugins create conflicts. Please check your search widget in the menu. It does not work as well. That is a js error you have going on.
Please try to deactivate all plugins except visual composer, clear cahche and reset cdn files if you use it.
Then check the smartlists again.
PS. There is a newsmag forum as well. This is the newspaper theme forum.
