In order to remove the ads, you can use this code for the post style 1 ad:
.td-g-rec.td-g-rec-id-post_style_1{
display:none;
Unfortunately the ads will not fit that way. What you can do as an alternative is use this code so the text will flow in the right side: http://screencast.com/t/BOyuIPqPutZb
.single_template_1 .td-g-rec-id-content_top{
float:left; padding-right:20px; padding-top:20px;
I hope this helps
