I would like to define the maximum height for the featured image on posts with Style-3.
Actually I did expect that your theme already does that but I regenerated two test images and they sty in their uploaded aspect ratio.
Is this an error with the image?
Can I define a max height?
Hi zumaxb,
You can try to use the code below to change your max-height. Also you can adjust the max-height values as you wish. The min-height is 300px, the value standard set by theme.
Place the code below in Theme panel->Custom Css area, like this: http://screencast.com/t/K1VzkPISlE
.td-post-template-3 .td-post-featured-image {
max-height: 400px;
The result should see here: http://screencast.com/t/gKvoYbq7
Please make sure that your max-height is not less then your image height because in this case the image will be cropped.
I hope this helps and let us know how it goes!
