Post Template 3 not required from page number 2
Hi Team,
We have activated post template 3 , although it is good but we use pagination and we do not want this post template feature from page number 2 and onwards in each and every article. Can you please check for the possibility of this special change over
url :-https://desihutiapa.com/story/987/immense-benefits-of-drinking-water-on-an-empty-stomach/
Here is the Url for your reference , After Continue reading(or page number 2 and onward) we want to remove feature image from back ground of tittle.
do let us know the procedure to do the same in future too
Prompt action will be highly appreciated,
Sorry but this modification will not be easy to make. The post template needs extra conditions added to the code It is easier to just use another template that does not use parallax like the one you are using now (default post template)
The parallax post styles do not have the image inside the post content but rather on top of the post content, so paginating the post will not remove the featured image because it is not part of the same container.
