Post Template Problem
Hi, I have a problem with the videos in the entries in the Post template part, the video does not show the playback option youtube button does not appear to play.
I introduced the url of the YouTube video and it only brings me the cover image, in fact I have another installation where it worked fine.
It can be seen in the following link:
https://www.pulsovideojuegos.com/musica/rap-de-vegetta/
You can see the configuration of the post templete in the following image
Templete problem
Also when I try to change post templeta does not let me, could you help me with this? I would appreciate it too much
Are you making the post a video post? – https://prnt.sc/r3im97 If you don’t it will not work correctly. Please check.
Thank you very much, it worked for me, I did not notice that I had not put that option
