Post template settings do not work after 9.7.3 update
I tried to change POST TEMPLATE, however it does not work.
Please check version 9.7.3 for me. Thank you!
Unfortunately in Newspaper v9.7.3 there is a problem between WPBakery, tagDiv Composer, child theme and tagDiv Cloud Library, if you have the child theme activate the post templates will not longer work,this problem will be fix as soon as possible!
Thank you for your understanding and sorry for the inconvenience!
OK, before I go to the trouble of setting up a child theme so I can make changes to functions.php, I want to be sure I understand:
If I set up a child theme, none of the cloud templates will work? Is that correct?
And if that’s the case, and child themes no longer make sense with Newspaper, how should we implement customizations? Make them in the main files, keep a list of the changes we’ve made, and then make them again whenever there is an update?
In Newspaper v9.7.3 if you have the child theme active the only template that will be display will be the default one ( the ones from the theme will not apply and neither those from tagDiv Cloud Library ).
Also now using tagDiv Composer with header manager and tagDiv Cloud Library you can do a lot of customizations.
Thank you for the reply.
So, the second part of my question is correct, as well. We have to make changes to the theme itself, keep a record of them, and re-make them whenever the theme is updated.
I understand your team’s need to deal with Envato’s requirements, since that is your sales channel. But the loss of child themes is a major setback, in my opinion. I hope you find out a way to fix this in the future, either by reimplementing child themes or by adding some sort of functionality into the theme itself that allows customizations and then remembers them during theme updates.
You can check/try the solution provide by an user in this topic -> https://forum.tagdiv.com/topic/issue-with-9-7-update-changes-single_template_-in-child-theme/ or you can get the Newspaper v9.6.1 from here -> https://forum.tagdiv.com/topic/important-new-update-newspaper-9-7/
