Post title block modules
Post title block modules – how can I change font type and font size.?
Thanks in advance.
Hello Frydenborg,
If you want to change this, you should use a bit of CSS code to do this. Try the code below and place it in Theme panel->Custom CSS area.
The code is ->
.td-module-title{
font-family:arial;
font-size:20px!important
The result is here -> http://screencast.com/t/VEBWjPPVadI8
