I searched to see if it is possible, but wasn’t able to find an answer. In the capitalization section of the font table in the theme explorer, is there a way to enable small caps? In essence, it’s where the entire line is caps, but the actual capitalized letters that are input are a few sizes larger than the lowercase letters.
Any help would be appreciated.
Hello thedowntowndweller,
Unfortunately, I do not exactly understand what you want to achieve. Please notice that these are the only options from fonts which might be set in Theme panel from Post title, like this => http://screencast.com/t/To6yet5o What do you mean exactly?
Small caps is where all the letters are capital, but the ones that you did not capitalize when inputting them are simply a smaller font size than the ones that were capitalized.
See this for information: http://www.w3schools.com/cssref/pr_font_font-variant.asp
Since it is supported in CSS, it would be very helpful to have this functionality in the theme. It is very common in headings for print media, which is what this newspaper theme does such a good job or parlaying in the digital realm.
Hello
Unfortunately, this type of functionality it is not implemented in out Theme panel but please notice that you can use it with some CSS code. As an example, please look this screenshot like this -> http://screencast.com/t/zYQEQun0dsoH
If you need more assistance in this regard, please provide your website URL so I can inspect it closer and also, so I will be able to provide a more accurate response.
