Post Types and Block
How to display taxonomy (Gentry, author) with the unit Block ???
The unit Block does not see in the editor ((((((((
How to display the main page with the help of selected entries from the taxonomy book?????????
what to do?
<!– copy and paste. Modify height and width if desired. –>
Our blocks can display a custom post type but you have no control over a custom taxonomy though. If you want to show a book post type in a block you can simply type in the book type like so: http://screencast.com/t/05CUStsO
If you used our plugin and created the td_book CPT, you can set it from the block settings to display on your homepage: Simply use the ID you gave your CPT (our plugin uses ‘td_book’)
Thank you for your advice
But your td_book plugin allows you to create a taxonomy but not work in the future with them (((
the maximum that it is possible to bring them the list of such criteria without the ability to select a specific taxonomy
respectively, the diversity of output patterns in the subject do not work with taxonomies and become useless
Hello urlovod,
Unfortunately, this is the default theme’s behaviour and if you want to make the theme working deeper in this case you will need to do some additional customizations through code that involves custom work and we cannot provide this type of services at the moment, sorry! If you are not aware of the steps in this regard, please consider hiring a freelancer/developer to help you!
