POST VIEWS not working after using Wp Cuper Cache
How you guys are doing? I just found one issue and need a great suggestion from you guys. Actually to improve the website performance it needed to use Wp Super Cache in my website that has been developed with your Newspaper theme.
Now everything is working great but issue is the post views are not always updated untill I clear the cache, I am aware it is obvious to happen but I was wondering if there is a way you guys can suggest some code that will manage it to be done by AJAX or something.
Any help is highly appreciated.
Thanks Sanny
Please make sure that you have enabled also Ajax view count from Post Settings – http://screencast.com/t/ldAXjWcJ4Red and also we recommend to use WP Super Cache on default.
