I have removed all widgets from Newspaper default sidebar but at posts remainings old widgets.. take a look here: https://ibb.co/bmvbS1Z
http://new.fansofporn.com/nelly-kent-interview/
How can I delete them?
Thanks for your help!
Best Regards!
For this you need to edit the single post template from tagDiv Cloud Library (that you are using) with tagDiv Composer like this -> https://i.imgur.com/xBwvjuJ.png -> and if you want to remove it you can use the right click like this -> https://i.imgur.com/MBKv2pd.png and you can set the elements you want!
Hope this will help you!
I have a another question, how it is possible to disable all posts load from here: http://new.fansofporn.com/nelly-kent-interview/
I want to load just one post and related articles.
Best Regards!
This reply was modified 6 years by
slayprodwork.
I’m assuming that this problem appear on posts that have set infinite loading, you’ll need to edit the single post template with tagDiv Composer and disable the infinite loading.
-> https://tagdiv.com/infinite-loading-for-single-posts/ from post -> https://i.imgur.com/yIf6fA3.jpg -> https://i.imgur.com/KeclHLS.jpg -> https://i.imgur.com/4jHIHFY.png
If this is not what you mean, please provide some more details and some screenshots.
I have moved my site to live domain.
I want to set Single Post Template – Default PRO Used On All Posts how it is possible. Current settings: https://ibb.co/ZgJrH23
Thanks & Regards!
After you get the single post template from tagDiv Cloud Library you can set it on all posts that have set the style/template “From panel” -> https://i.imgur.com/I01wdlY.png by setting that cloud template in Theme panel > Post settings> Default post templates -> https://i.imgur.com/gHinGr1.png also you can check our check tutorial fro this -> https://www.youtube.com/watch?v=I1R3j1QYod0 -> https://www.youtube.com/user/tagdiv
