Posts and categories not matching right
Hi everyone,
I just installed Newspaper theme on my blog (replacing a previous template). And for whatever reason, my blog posts don’t show up in the expecting categories in the menu. Some posts do, some don’t. Some categories are totally empty, some are quite full and some other have 1 o 2 posts instead of 10 for example. I tried all day to fix that, trying the following :
– I checked in the back office if my menu was still ok, uploaded it again in case, no changes.
– I created new categories to move on the missing posts into it, but it doesn’t appear either in there.
– I know the missing posts are still available somewhere on the blog, coz I find them when I use the Search bar.
– I tried to tick the categories box again inside the missing posts, no changes.
– And the most bizarre : if I tag a post from a category inside another one, this one empty, I finally see a post appearing, but not the one I just tagged. The post appearing is one belonging to the empty category, and who wasn’t available previously, wt*** ? Unfortunately, the post won’t remain if I untagged the first post belonging to the other category. I really don’t get it.
I guess my back office and the Newspaper template don’t speak properly together. Maybe this could be fixed quickly inside the code but I don’t code at all unfortunately. If you have any idea how to solve this issue, I’m in and thank in advance !
Nastasya
Thanks guys ! Nat
Hello !
